SailNet Community - View Single Post - Source of Weeping leak into bilge? maybe?
Old 03-14-2010
GlacialEratic GlacialEratic is offline
GlacialEratic is on a distinguished road
I need some sage repair advice. My 1985 Pearson 303 has an internally ballasted keel. I bought it on the hard last april and had to have it transported about 50 miles from 'there' to 'here' last June 1 when it was launched. While I didn't do an inspection between the time the hauler picked it up and delivered it before it hit the water, I soon thereafter identified a weeping leak into the bilge. Leak rate was about a couple gallons into the recessed bilge in 24 hours, and identified the entrance point where the rear of the bilge recess ended, at the top where the recessed area met the hull at the aft end of the bilge. When it was hauled in October I saw a significant crack in the fibreglass exterior at the rounded aft end of the keel at its upper point where that trailing edge meets the hull. Can't tell the depth of the crack (appears 1/4 inch deep or more) but it extends about 2 inches on both port and starboard faces of the keel starting at a point a couple inches below the hull/keel joint and at a 45 degree angle upward as it extends forward.
It wasn't there when I scaped and repainted bottom paint just prior to the June 1 transport and launch.
I've been reading the West System manuals in anticipation of a fix and have this question. How do I determine what different weights / types fibreglass fabric to use to lay up this repair after I grind open the fibreglass to see the extent (depth) of the damage?
Any words of wisdom or experience out there? Launch is May 15 and the weather here is ALMOST good enough to start this and all the other minimum requirements for pre-launch maintenance.
