Old 03-14-2010
sailingdog sailingdog is offline
I'd point out that if you're going to be fishing the wiring for the panel through a dinghy davits or other stainless steel tubing, the MC4 cable ends are going to be a BITCH. This is why I recommend the panel with the junction box. Also, the MC4 cables are untinned, non-marine grade wire IIRC.
Originally Posted by LookingForCruiser View Post
Or get this one instead, even cheaper:
Kyocera KD135GX-LPU 135 Watt 12 Volt Solar Electric Panel
Only difference between the two is you'll need to get their special MC4 cable. The one SD linked to has a junction box, not a plug.
