Old 07-23-2001
RichH's Avatar
RichH RichH is offline
RichH will become famous soon enough
Plexiglas Maitenance
Wet sand starting with 600 grit wet and dry sandpaper then 1000 then 1300, then 2000 grit. Use a few drops of detergent as a lubricant. Use a flat rubber block or disc to hold the sandpaper flat. This will give you a matte finish.
Then buff with a cloth wheel (not a pad) at mediium speed with a ''bit'' of jewelers rouge on the wheel. Go slow and easy on the pressure when you power buff ... or you will burn/soften/distort the plexiglass surface.
You will wind up with an optically clear surface; but, it will have image distortion.
