Old 03-15-2010
sailingdog sailingdog is offline
A topping lift is usually a line that goes to a block at the aft end of the masthead, and then runs down the mast. It is generally used to lift the boom when the mainsail is being lowered, while the mainsail is furled, and while the mainsail is being hoisted.
You might want to get the owner's manual for the boat from HERE.
They also have the rigging specifications, located HERE. It appears that there was not a topping lift on the boat as it was originally rigged. There was a Spinnaker topping lift, but not a boom topping lift.
As for the canvas, any decent marine canvas shop should be able to make the skirt. There should be some sort of fasteners on the inside of the poptop as well as on the cabin top around it, which were originally used to fasten it. Upgrading the fittings can make the poptop far easier to install. For instance, using a boltrope and track, instead of snaps.
