Old 07-23-2001
pmills42255 pmills42255 is offline
pmills42255 is on a distinguished road
Question on Roller Furling Jib
Rob,
I just installed a Harken MKIII on my boat. The directions called for unstepping the mast, but I did it with the mast up. Took a little nerve, but otherwise a straight forward install. The components are nicely made, and sturdy. The system works like a dream. I am using an old 150% genoa and it furls nicely. As far as reefing, well, it does, and what I want is a smaller sail, and that is what one gets. Understand how the thing is supposed to work and it will go together any way you want. I did need to buy a swag fitting because the existing one has to be cut off. Think about what that means when you plan the install. If the existing system hasn''t got many threads left to use in the turnbuckle, you need to extend it the length you cut. If the turnbuckle is right to the end, you can use the threads to make up the differance. My ONLY concern is and still is the swag fitting. I wish I knew more about them. I also bought the wrong pin but managed to shrink it with a file and a drill.
have fun
Paul Mills
