SailNet Community - View Single Post - Catalina C27 Tall vs. Std. Rig Fin vs. Wing Keel
post #3 of Old 03-16-2010
sailingdog
In a nutshell:
Basically, the tall rig will give slightly greater performance due to the greater sail area, but be more tender than the standard rig due to greater sail area and more weight a loft.
The wing keel will usually be a bit more tender and a bit slower due to increased wetted surface area from the wing, but will give you a shallower draft. The fin keel will be a bit stiffer, sail upwind a little better and require more water.
sailingdog is offline
