SailNet Community - View Single Post - Cockpit Speakers
post #3 of Old 03-17-2010
sailingdog
Another worry is if the speakers are mounted in an area that opens to the bilge. If the boat gets pooped, will water get into the hull that way? If the space opens to the bilge, it would be wise to mount the speakers under deck plates that can be closed off in bad weather.
As for the binnacle, I believe the OP is referring to the distance the compass will be from the speakers, since it is mounted on a binnacle... not that the binnacle would shield the compass.
Originally Posted by Groven View Post
Just keep in mind that wherever you place them, the weak link in that bulkhead/surface will now be the speaker cones/surrounds. They break down incredibly fast in the UV and then allow water intrusion. When I installed my new cockpit speakers last year, I couldn't find a single company that made speakers with optional covers. I now use a pair of small rubber dog frisbees to protect the speakers from UV degradation when not in use after a pair of Clarion marine cockpit speakers completely disintegrated in only 6 months.
Also, I would not expect a binacle to eliminate magnetic interference.
sailingdog is offline
