SailNet Community - View Single Post - Filling in holes in the deck
post #29 of Old 03-20-2010
KeelHaulin
STARBOARD!!
KeelHaulin's Avatar
Make sure you use heavy gauge wire (like the size of battery cable) and have good watertight seals on the lugs (adhesive lined heat-shrink) so the wire does not corrode from exposure to moisture. I would not coil the excess wire as you suggested; better to cut to the correct length and then connect the lugs and seal.
KeelHaulin is offline
