SailNet Community - View Single Post - Making the Cal 29 forward stanchions bullet proof
post #1 of Old 03-20-2010 Thread Starter
tommays
tommays's Avatar
One of the areas that always fails on boats is the stanchion bases because the glass is so thin compared to the abuse they take in day to day sailing
Both of the forward stanchions had cracked the inner and outer hull skins allowing water to soak the core to avoid this in the future i fitted 1/2" thick 8" x 6" G10 blocks which will put the load into 48 sq inches of deck compared to the original 6 sq inches
Nothing on a boat is every easy and this was no exception as the port and starboard stanchions were different enough i had to drill each block up different
I went with MAS brand epoxy because i like the 2:1 ratio and the containers are easy to pour from
I am using chopped fiberglass to thicken the mix at about one teaspoon per OZ so far as it seems to add a LOT of strength compared to other thickeners
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
