SailNet Community - View Single Post - rubbery material at hull-keel joint - what to replace it with?
post #3 of Old 03-21-2010
sailingdog
That looks like bare metal. IIRC, the Bendytoys used iron for the keel material...and having exposed metal like that is bad.
When you did the work last year, did you drop and re-bed the keel or just work on it as it was? If you didn't drop the keel, inspect the bolts and re-bed it, you should probably do that now.
sailingdog is offline
