SailNet Community - View Single Post - On-mast pole storage
post #5 of Old 03-22-2010
GeorgeB
GeorgeB's Avatar
Iíve seen Santana 22ís out here that store their poles along side the boom, resting inside a couple of rings (some guys use slings made out of line). Very quick and easy to run it out and set for a spinnaker run. On the other hand, I used to keep mine in the cabin and Iíd just pass it forward to the bowman. Small poles are easy to ĒmanhandleĒ (Iím assuming this is for your 18 or 21 footer?). The up on the mast is usually for boats with heavier poles and uses a T-Track at least as long as the pole, sliding rings or cars, topping lifts and all the associated blocks and control lines. The setup on my 34 footer was mucho expensive. It might be over kill on your boat(s).
GeorgeB is offline
