Visual inspection is a good start, if you can get under the boat well enough to look up into the centerboard trunk. Looking for staining will often give you a good clue about conditions, as a damaged trunk or rusting pivot pin will often have some external signs of the damage or corrosion.
Unfortunately, to really see what is going on, requires lifting the boat and lowering the swing keel or centerboard.
