SailNet Community - View Single Post - holding tank vent
post #6 of Old 03-28-2010
sailingdog
Originally Posted by good5buck View Post
ADVICE WANTED
I have similar questions about venting a holding tank. I'm in the final stages of a new holding tank installation; my tank was built with two vents but my mechanic has very different ideas than I do about the location and number of vents ... I would welcome some advice to resolve our impasse:
* Specifically, he wants to plug up the aft vent on the tank rather than go forward with two vents.
* As for the forward vent through-hull, he's concerned about siphoning, so he wants to run the vent hose in a loop above the through-hull before connecting rather than doing a straight run from the tank opening to the through-hull.
Really bad idea... will basically stop any air flow and cause the tank to load up with anaerobic (stinky) bacteria.
* In addition, he's inclined to locate the single vent through-hull on the side of the main cabin to reduce the risk of siphoning.
* As for me, I've been inclined all along to think there should be TWO vents, to run the vent hose in a straight path to the through-hull, and to locate them just below the toerail.
Good idea, provided they're actually two separate vent lines with separate tank openings. Maximizes the airflow through the tank and helps promote the low-stench aerobic bacteria.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
sailingdog is offline
