SailNet Community - View Single Post - Need some info on Roller Furling
post #3 of Old 04-13-2006
sailandoar
sailandoar's Avatar
I suspect that they mean you should be able to pull the fuling line and roll the sail up 'by hand' when there is not a lot of wind pressure/tension on the sail. At the dock or drifting in a near calm, if you have to use the winch then something is binding/draging and adjustment or lubrication is likley called for. One of my favorite and most productive research methods is to ask, "can I please speak to someone in technical support". Works like a charm about 85% of the time.
sailandoar is offline
