SailNet Community - View Single Post - Everthing I know about outboards.
post #10 of Old 04-01-2010
sailingdog
I would point out that what is more important than HP is having the right prop. Most of these outboards come with a prop that is better suited to moving a light aluminum jonboat at higher speeds rather than the higher power, lower speed prop a sailboat needs.
Getting the right prop, so you can use the engine at WOT and have the power you need to keep the boat at "cruising" speed is essential.
How much does your boat displace? The typical rule of thumb is 1 HP / 500 lbs. of boat or so. I doubt your boat is 5000 lbs, so 9.9 is probably too much HP for it.
sailingdog is offline
