SailNet Community - View Single Post - seeking advice on tapering an aluminum mast
post #5 of Old 04-01-2010
Faster
Originally Posted by sharedwatch View Post
Greetings folks,.....I am re-rigging my boat and will be converting a mast section from mast head to fractional rigged.
I'd be interested in what boat you're doing this to and what dimensions you are going to vis-a-vis the original rig. This could significantly shift the C of E of the sailplan if the mast isn't relocated at the same time. Details?....
As far as putting the taper in, strength/wisdom issues aside I believe it's usually done by cutting a vertical wedge in the leading edge, squeezing the section together again and welding the resulting seam.
Faster is online now
