SailNet Community - View Single Post - Bedding Deck Hardware With Butyl Tape
post #20 of Old 04-06-2010
sailingdog
If the aluminum framed ports have the frames screwed or bolted to the boat, then sure, butyl tape is perfect... Plastic frameless port lights should be adhered using Dow 795 structural silicone adhesive.
Stuff under the water line, through-hulls near the water line, and anything that may be exposed to significant amounts of fuel, like the diesel deck fill, should also not be bedded using Butyl, since butyl dissolves in petroleum products.
Originally Posted by davidpm View Post
So butyl tape for deck hardware, tracks, chain plates, cleats, clutches etc.
What would you not use it for.
Hull, deck is 5200, you want to super glue effect right.
What about aluminum framed port lights?
Plastic frame less port lights?
sailingdog is offline
