SailNet Community - View Single Post - Cruising RPM
Thread: Cruising RPM
post #15 of Old 04-06-2010
sailingdog
The hull is clean and so is the prop... so the prop is mismatched and you're not able to get anywhere near what the WOT RPMs should be... I'd say you're over-pitched by about THREE inches, since each inch will drop or raise the RPMs about 200 RPM. That would bring you up to 2600 RPM WOT... which is not bad for an engine that has a redline of 2800 RPM.
This would bring your cruising RPM up to about 2200 RPM, as suggested by Maine Sail. This should also lower your speed when idling.
Originally Posted by MobjackB32 View Post
The hull is clean and the prop was checked and cleaned 1 hour before the trip started. WOT in gear produces 2000 rpm, out of gear 2500+ rpm. She also runs about 3 mph at idle. the prop is large and 3 bladed. Large meaning just fits in the space within the full keel.
sailingdog is offline
