SailNet Community - View Single Post - Fuel leak in injector pump
post #1 of Old 04-10-2010 Thread Starter
RussT1950
Hello to all,
I have a Cat 30 with a M25xp diesel motor. Sometime ago I noticed a fuel leak where the injector pump screws into the block. (I think its the injector pump). The leak is pretty bad going into the bilge and causing the whole boat to stink. Is there some type of metal washer underneath that might be bad, or will tightening it do the trick. Only wrenches I had this time were standard. Any advice would be appreciated
Thanks, Russ
RussT1950 is offline
