SailNet Community - View Single Post - Fuel leak in injector pump
post #2 of Old 04-10-2010
erps
the pointy end is the bow
erps's Avatar
Have you done anything to the pump or injector lines lately? The metal tubes that supply the injectors with fuel are under high pressure. I would start checking where those lines fit into the injector pump. Maybe its leaking there and running down where that flange is and giving the appearance that it's leaking there. Check your dip stick too incase the pump is leaking in the body and leaking some fuel into your oil.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
