Originally Posted by BirdBrain333
Replacing the Diesel fuel tank on our PSC 37 I am debating between a welded Poly tank and an aluminum tank. If they ever add ethanol to diesel the poly tank will, I am told, leak like a proverbial sieve. Price is about the same.
Anyone out there have any idea how likely it is that ethanol will make its way into diesel fuel supply?
Jay
PSC 37, Kenlanu
... so what is the leak concern? I think you have been misled.
That said, adding ethanol to diesel is moronic on several levels, and the safety folks should prevail... I certainly hope!
That said, the EPA is looking at it, at some level.
Enhanced Ethanol Diesel Blends for Emission Reduction| Research Project Database | NCER | ORD | US EPA
7.5 - 15% (the levels normally discussed) will be enough to make diesel flammable, though in a different way from gasoline. Curiously, it may be safer in one sense to be at the higher end of this range, as 3-7% mixtures carry a risk of tank explosions, as the tank would be in the combustible range (diesel is below the range, gasoline is above the range).
