SailNet Community - View Single Post - Engine Mounts/Bushings/Isolators - Alignment?
post #1 of Old 04-11-2010 Thread Starter
T37Chef
T37Chef's Avatar
Where to start...
The cutlass bearing has failed terribly, probably due to poor alignment It did enough damage to the shaft that I will be replacing it along with a new coupler, tranny saver, and engine mounts/bushings (I think the mounts were/are the culprit). While I'm at it I am going to install a PSS Drip-less and a Spurs Shaft Cutter.
I have done a cutlass before, no biggy there. The tranny saver & coupler shouldn't be a problem either, but would certainly welcome any tips. What I am not as comfortable with or know much about is replacing the engine mounts followed by the alignment process.
  • What/where do you buy a mount/bushing/isolator? Using the Westerbeke 50 part # I went to Torresen Marine and found them but they seemed $$$, $168 each. Then I read Pascoe Marine Engines : Drive System Alignment by David Pascoe, Marine Surveyor and he mentions another type of mount, the Ace Mount???
  • Tips on how to remove and replace the mounts,
  • BTW, anyone removed a Autostream prop? How? Is it just the two set screws, West by North has yet to return my phone call or email.
Thanks
Shawn
T37Chef is online now
