SailNet Community - View Single Post - Keel Joint Issue
post #2 of Old 04-12-2010
sailingdog
When was the last time the keel was dropped and the keel bolts inspected? The boat is 34 years old, and if this hasn't been done in the past ten years, it probably should be done before doing anything else. Then you can properly re-bed the keel-hull join and tighten up the bolts.
sailingdog is offline
