SailNet Community - View Single Post - Mildew/Ventilation problems.
post #10 of Old 04-12-2010 Thread Starter
Triquetra
Triquetra's Avatar
Triquetra—
The two I have aboard currently are older models that actually screw into a metal deckplate. In heavy weather, or if I anticipate going out in really bad conditions, I can unscrew the vent and plug the hole with a screw-in bronze deckplate. This is about as waterproof as you can get.
That said, I've yet to get water into the boat through them, and I've had waves wash over the cabintop. I am installing a less robust model for the anchor locker to help keep the anchor drier.
The new lower end models have a sliding sleeve that can close off the vent and prevent water intrusion in 99% of the cases... and seem to work quite well, but I've no personal experience with them other than seeing them on friends' boats.
SD, I appreciate all of your input on this. I was not certain of the newer models, though I only saw the lower-end ones at the store. The plastic ones just pull out as opposed to screwing into the deck plate, which is probably why I heard the stories of them getting yanked out by lines. The metal ones are probably the ones I should be looking at. Thank you.
Triquetra is offline
