Old 04-13-2010
Sailingchefs Sailingchefs is offline
Sailingchefs is on a distinguished road
Bilge Pump Installation
Hi all,
Trying to update the boat with an electric pump. After doing some research, I'm looking for some experiences with this job.
I decided to go with the Rule 2000, with it's own thru-hull, in addition to my soon to be rebuilt manual pump.This should give me, all things considered, about 1700-1800 real gallons per hour, plus a manual piston pump.
Here are some of my concerns, in no particular order:
-Suppose I wanted to be even more OCD, and install a smaller Rule 500 Fully Auto. (that I already have a couple of) in a slightly lower position in the bilge as the (yachtsurvey.com) bilge pump page suggests. Does that necessitate yet another thru-hull, or some ingenious combination of Y's and anti-backflow devices? It does seem less of an issue than with tapping into the manual pump's hose, since the smaller, lower one would also be running and largely irrelevant if the 2000 needs to kick in. Sonnet II will be on a mooring for the summer, and although I usually get out once or twice a week, I have no good way to recharge the batteries without running the motor. (Only a tiny cheap solar panel, and no new one in the budget.) I like the idea of the tiny low-draw pump taking care of small amounts of rain water while I'm not around without killing the batteries. As everyone says, its likely to stay dry and never be an issue anyhow. Just a bit of mental comfort and extra redundency for two sailors who took turns working a 3ft. man. piston pump for 2 1/2 hours non-stop, literally for our lives,one evening last fall.
-One of the tech guys I spoke to today explained to me that the anti-siphon loop was the point in the new pump's discharge hose that the water would drain back into the bilge from when the pump shut off, possibly turning it back on. I had thought to put said loop just forward of and higher than the new thru-hull, but that leaves the maximum length of hose to drain back into the bilge. Tech guy suggested I put the loop as far forward, close to the pump, as possible. I know all the different years and models have different bilge layouts, but does any one have a strong position on the best route for the new discharge hose and placement of the loop considering this back flow issue? Maybe it's high up just forward of the manual pump in the laz.? (In a 1984 Catalina 25)
-And about this vent in the loop; what is it called, and who has them?
Why do they get blocked, as they apparently do?
-The DPO seems to have added 3-4 ft. of smaller diameter clear vinyl hose, through a Home Depot reducer, to the end of the manual pump's pick-up hose. It does a loop back aft so the cut end rests on the floor of the bilge. Could this have been intended to prevent back flow from the manual pump? Doesn't seem like it would.
The larger, original black hose lays flat on the floor of the bilge, but from my reading, it seems it at least needs a strainer installed on the end. Agreed?
-Every one refers to the manual pump's thru-hull as being 6 inches above the waterline. As it happens, the center of my thru-hull is 3 1/2 inches above the waterline, and mine looks like all the others.
Since the top of the keel/ bottom of the bilge is not quite 2 ft. below the thru-hull, I'm thinking putting the new hole a few inches higher on the transom wouldn't be so bad. It sounded like it was placed lower not just for less static head, but to minimize splash/staining on the hull. Since this pump should never turn on anyway, not an issue right?
-For the wiring, I'll probably go with the Rule 3-way switch; wire it directly to the panel with no breaker, and mount the connections in the bilge as high as possible with shrink connectors and a dab of dielectric grease.
-Since our current Honda outboard motor is a pull start with a generator, I'm looking at going with 2 of the largest marine deep-cycle batteries that will fit in the battery locker. I have yet to measure this up. Anyone care to chime in on their favorites or what the max. size that will fit is?
Thanks, Glenn
