SailNet Community - View Single Post - J-Boat 41
Thread: J-Boat 41
post #10 of Old 04-14-2010
I would add that you should get a clear picture in mind of what kind of sailing you really want to be doing. If you want to daysail, especially shorthanded, then you should look at a smaller boat. The bigger the boat the more it costs to operate, the more effort is required for even short daysails, with the result being that you will use it a lot less. If you are thinking about living aboard, that brings up a whole other set of issues, but chances are you would be doing little daysailing at that point too.
When you see a boat like a J41 advertised for what seems like peanuts, it can look like a winning lottery ticket someone dropped on the ground. I promise you that is only an illusion. There is a reason why the boat is that price, and it is because it has a very narrow range of uses, and costs a ton of money to run.
SW329xl is offline
