SailNet Community - View Single Post - Gear shift control cable
post #10 of Old 04-15-2010
JiffyLube
Grasshopper
JiffyLube's Avatar
You should be able to find the information you need printed on the cable. An easy was to route a new cable is to attach a double threaded connector to the old cable, and the other end of the connector to the new cable. As you pull the old cable out through the pedestal (if you have one), you'll be pulling through the new cable at the same time.
JiffyLube is offline
