SailNet Community - View Single Post - Very Basic DC Wiring Question
post #2 of Old 04-15-2010
sailingdog
Ignore your brother. Get Nigel Calder's Boatowner's Mechanical and Electrical Manual and read the electrical section.
You will want to get the following:
A battery or two, depending if you want a house bank or not—I'd recommend having one for the lights/bilge pump and one for the motor.
A main battery switch—I'd suggest a BlueSea Dual Circuit Plus type switch so that you can turn on the electric trolling motor and the house bank for the lights at the same time.
Nav lights—preferably LED to keep the electrical draw down.
Bilge pumps
A six-switch Blue Sea WeatherDeck fused switch panel
Two primary fuse holders, one for each battery.
Marine grade wiring—I'd recommend ordering from Genuinedealz.com as they will crimp the battery terminals onto the wiring for you.
I would also recommend you read Maine Sail's post on terminating marine wiring. Located here.
sailingdog is offline
