SailNet Community - View Single Post - Yanmar 2GM20F Work...
post #9 of Old 04-18-2010
klem
I would agree with bljones recommendation. Once you have checked fluids and filters, the only normal adjustment required is the valves. This is something that you can learn to do quite easily if you have no previous experience. Very few diesels are designed as interference engines so even a valve that is badly out of adjustment is usually not a big problem.
klem is offline
