SailNet Community - View Single Post - Locating the master battery switch / DC Panel - Wire cost
post #4 of Old 04-19-2010 Thread Starter
jarcher
jarcher's Avatar
Thanks guys...
Even if someone goes and switched all the bulbs from LED to halogen, max possible load will probably never even approach 30A. I was thinking I should swap the main breaker in the panel from 50A down to 30A, because I don't want the wire to be too small for the breaker if i size for 30A.
But then you mentioned a fuse in the positive feed wire. So if I fuse the feed at 30A right near the positive battery terminal (on just the house battery) then I guess that issue is resolved.
But in that case, why do I have a 50A breaker on the panel?
Helios
Scampi 30 MK-IV
jarcher is offline
