Thread: Hull Keel Joint
Old 04-20-2010
sailingdog sailingdog is offline
It looks like there's a parallel stress crack in the gelcoat in the second photo. I'd think you'd want to at least look at the laminate there, rather than just fairing over it. The impact may have been more damaging than you think. You're seeing a crack in the gelcoat that is WIDE ENOUGH so that you're seeing light come through the fiberglass, and it doesn't look to be the normal separation that occurs at a hull-keel joint.
