Old 04-22-2010
chrissailorman's Avatar
chrissailorman chrissailorman is offline
Blue Hawaii at dusk
chrissailorman is on a distinguished road
Regarding bridges between Sayville and Shinecock.... You can sail the entire distance... all bridges between the two points will open and let you through...I,ve done it. Prepare for a looong sail however. Once you get to the canal you will need to drop your mast, and the currents in the canal can be pretty strong as well so check your tides and plan accordingly, and be sure your motor is healthy.. Once through the canal, (I've never done that), you're in the Peconic and on your way to Southold. Sounds like a great sail to me. Be sure to have healthy crew for dropping and raising your mast. Alternately, you could rent a boat trailer and haul it yourself to Southold. That shouldn't be too bad. My 22, a Rhodes, trails very easy and I can even tow with a small pickup (Ford Ranger).
