SailNet Community - View Single Post - Gemini 105MC Slow speed under power
post #2 of Old 04-24-2010
pdqaltair
pdqaltair's Avatar
* Dirty bottom. it would take over 1/4" to cause that.
* Dirty prop (worse). Would vibrate a lot, but you might not notice without a baseline.
* Engine RPMs. Did it get to full revs?
* Waterline. Is she lower in the water than other 105mcs?
The first is most likely, and it could be that bad. If it is, require that it be cleaned for the survey.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
