SailNet Community - View Single Post - Gemini 105MC Slow speed under power
post #16 of Old 04-24-2010
FSMike
FSMike's Avatar
If the engine is reaching full rpm then the horsepower is adequate. With the boards up, if the speed is still lacking, it pretty much has to be a propellor problem or trans slipping since you say the bottom is clean and you are discounting weight as a factor. You might consider having a mechanic use a test tach to verify that yours is accurate, but that's grasping at straws. I have to admit that I would be tempted to offload everything I and a few strong friends could carry and then see what happens.
Good luck.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
