SailNet Community - View Single Post - Possible new owner
post #2 of Old 04-25-2010
DMD
Paul,
One item to check on an early model PS 37 is the aluminum fuel tank in the bilge. These tanks are vulnerable to corrosion from bilge water or accumulated water inside the tank. Later model boats came with a fiberglass tank. The tank is easily removable for replacement or repair, so an aluminum tank should not be a deal-breaker in an otherwise sound boat. Another area to check is the compression post, as I have heard of some boats with compression post damage from water intrusion through the mast step or shower (head area). Good luck in your search,
Dave
Crealock 37 #151
"Eowyn"
DMD is offline
