SailNet Community - View Single Post - anchor locker drainage problem
post #4 of Old 04-26-2010
sailingdog
What is access inside the boat to that area like. Ideally, you should replace the anchor locker drain and unless the bronze through-hull is in good shape, it should probably be replaced as well.
Posting photos of the anchor locker as well as the interior of the boat where the anchor locker drain and that through-hull are located would help.
sailingdog is offline
