SailNet Community - View Single Post - anchor locker drainage problem
post #5 of Old 04-26-2010
jjablonowski
jjablonowski's Avatar
Not knowing what your boat make or model is (you can put that info in your SailNet public profile, by the way), I'd hazard a guess that your cracked anchor-locker drainpipe is a straight line to the prow exit.
I'd re-line the pipe. Find a smaller-diameter copper tube or even plastic pipe; create a bell-shaped flange in one end; stick it into the drain hole in the anchor locker and caulk under the flange.
jjablonowski is offline
