SailNet Community - View Single Post - cutlass bearing replacement 31
post #16 of Old 04-26-2010 Thread Starter
orientalnc2010
orientalnc2010's Avatar
Hi T37,
Good recommendation about the extra insurance with an extra collar on the shaft. A doughnut zinc placed behind the rotor should do the trick.
What engine go you have? I had a westerbeke in my previous boat and at certain RPM's anything loose down below would rattle. The yanmar in my PSC is much smoother, I would not have thought that the engine was out of alignment,
only when my conventional stuffing box would not stay cool did I investigate.
Did you pull your shaft and have it checked for straightness? Also have the shop face your coupling to the shaft. This too is good insurance that alignment will be correct.
Regards,
Steve
PSC 31 #125
Ryoko
Oriental, NC
One of the two happiest days in a sailors life
orientalnc2010 is offline
