SailNet Community - View Single Post - Seal companionway tracks to FG and gel coat.
post #6 of Old 04-26-2010
Freesail99
Freesail99's Avatar
ZZ—
Through bolting them with the proper bedding compound would make them far more secure than using just a sealant alone, even 5200 wouldn't be as secure as having them through-bolted with a proper backing plate.
If you're worried about someone unscrewing the bolts... put a second locking nut on the inside...and that should prevent them from being unscrewed without access to the interior of the boat.
If I was bolting or screwing the C channel to the boat it would be on the inside of the channel and when the boards were in place, the bolts or screws would be covered by the boards.
S/V Scheherazade
Freesail99 is offline
