SailNet Community - View Single Post - ASA 101 - Basic Keelboat and the "Plan"
post #3 of Old 04-27-2010
sailingdog
Sounds like a well thought out plan.
One thing to consider is volunteering or working at the sailing club doing maintenance, since that will also give you a head start on the non-sailing side of the skills you'll need for cruising. Learning to deal with engines—both diesel and gasoline; fiberglass repair; electrical work; plumbing; etc, is going to be very useful when you get to the point of owning a boat. The more work you can do on it yourself, the lower the cost of ownership will usually be. You'll also have a better idea of how your boat is setup and how you can fix it when something goes wrong.
sailingdog is offline
