Originally Posted by btrayfors
No problem extending the coax. It can be any length. However, be sure to use quality coax with good connectors properly affixed to the coax. You'll need a UHF barrel connector. Tape or shrink-wrap the connections.
Bill
I'm breathing a sigh of relief. I have the transceiver mounted now and connected to the modem and am starting to string the cables.
For next week, the tuner mount should be straight forward and then I am going to have a painful time figuring out how to reach the insulator on the backstay which was done by the PO very high above the bimini. I'll probably have to go up the mast and use a leash to lower down the backstay.
A l'eau, c'est l'heure
s/v Estrellita 5.10b, Wauquiez Pretorien 35
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. // To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. // To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
