SailNet Community - View Single Post - Moving Olympia to Alaska via 1967 Bristol 27
post #14 of Old 04-29-2010
sailingdog
Be aware that the 9.9 Tohatsu Four-stroke may be significantly heavier than the two-stroke and as such may present some problems. It may also be significantly larger too. If your outboard is in a well or on a bracket, make sure that the engine will fit or the bracket can take the weight and torque.
BTW, the 9.9 Mercury, Nissan and Tohatsu are really all the same engine, so if you can get any of them for less than the others, it doesn't really matter which brand you get, as they're all made by Tohatsu.
Better get cracking, cause May 9th is just around the corner.
sailingdog is offline
