Given enough room to work the shaft away from the transmission flange there is no reason you should not be able to remove the transmission in the water. On some boats there may be hull structure that prevents such movement, but even then it is not required to remove the shaft completely from the boat for this job and technically anything you could do on the hard, short of removing the shaft, can be accomplished with a diver in the water.
I've twice in the last 28 years removed the transmission from a Yanmar 3qm30 while in the water. Never had any issues. I just loosened the retaining nut on the stuffing box, disconnected the two flanges, moved the shaft back far enough for clearance and unbolted the transmission at the bell housing. I did have to lift the rear of the engine for access to the lower bolts. The transmission (for the 3qm30) is not unmanageably heavy but it was very awkward with the large bell housing and poor leverage angles available in the engine room(box). We were able to use a line from the boom to aid in the handling. Make sure the shaft is clean before you push it into the stuffing box and I also was careful to keep it fairly well aligned while it was unbolted from the engine. Obviously if your boat has a configuration where the shaft COULD come out (ours can't, it's in an aperture) you would want to take precautions to prevent such an occurrence. In most cases I would imagine the shaft coupling would remain on the shaft and losing the shaft would be next to impossible.
After removal, we had it rebuilt and reversed the process to install. Don't forget to realign the shaft/engine even if you did not have to lift it as I did to get to the transmission bolts. I also replaced the packing in the stuffing box upon reinstall. Also don't assume the rebuilder has filled the trans with oil, check it yourself even if he says he did.
While the trans was out I did some cleanup and maint on the engine. There was MUCH better access with the trans and bell housing out of the way.
Good luck.
