SailNet Community - View Single Post - Pre-Trip Checkout
post #10 of Old 05-09-2010 Thread Starter
davidpm
davidpm's Avatar
Do you know where the main battery switch is? Do you know where the propane tanks are? Do you know where the emergency tiller is kept and how it mounts?
Thanks SD, you added a couple not on my list and made me think of a couple more.
How is the boat wired? Is there an echo charger? is the bilge pump wired directly.
How is the pressure water setup? Automatic switch? Will it burn out if left on?
Is the depth finder calibrated for water depth of clearance under keel?
davidpm is offline
