The real dimensions may not apply to your boat if the mast or boom has been modified.
Generally, there should be a small gap between the block and the head of the sail when at full hoist so that the sail can be tensioned a bit more when it stretches slightly, as often happens when sailing in heavier winds. The same applies to the foot of the mainsail. Often the boom and mast will have a black strip that indicates the full outhaul or hoist distance.
