SailNet Community - View Single Post - Engine will not crank and required charging time
Old 05-12-2010
Gary M's Avatar
Gary M Gary M is offline
Gary M is on a distinguished road
On most diesels after you turn the key you have to push the start button, did you do that ??
you generally want to run a diesel to get it up to temp after starting it and if it started right away 10-15 minutes should be adequate to recharge a battery.
