SailNet Community - View Single Post - Engine will not crank and required charging time
Old 05-12-2010
ekenna ekenna is offline
ekenna is on a distinguished road
Thanks for the suggestions. my responses in no particular order. The battery was only showing 12.5 ish volts not 13 on the boats. volt gauge It is only 1 cylinder and i do have a decompress lever so I will try that. Gary M the key starter switch is a 2 position switch. The 1st position powers the gauges and the alterator trickle the 2nd position activates the solenoid on the starter motor. just like a car. I know some newer boats have a 2nd switch or push button. Also there is no fuse between the switch and the solenoid or the battery to the switch (I know something I need to fix). I'll check this thread before I go from work tomorrow and let you know the outcome.
Boatless
