If you look into it the motor is NOT-rated for saltwater use which is also common in trolling motors
10. Can I use my Outboard in salt and brackish water?
The Briggs & Stratton 5HP Outboard is designed for freshwater use. Salt and brackish water are extremely corrosive and can lead to premature failure of components. Such failures are not covered under the Briggs & Stratton limited warranty.
Just like in the mid-west old mercury's are very common and in saltwater areas there mostly GONE because Evinrude Johnson and others used stainless drive shafts much sooner
Even some 90s Yamaha's had FAILURE PRONE steel shift shafts
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
If a dirty bottom slows you down what do you think it does to your boat To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
