I don't know where you can get a new starter, but I know old ones can be rebuilt.
Originally Posted by ekenna
Update
Last night went down to the boat. I moved the pulley driver by hand to check that it was not siezed. I started with the battery and worked through the wires to the solenoid checking the voltage. I checked the voltage at the wire that runs from the key switch when it was turned in the start position. I then checked the voltage on other terminal on the solenoid that goes starter. These all shows the 12.5 volts that were on the battery. Still nothing from the starter. I tried the decompress lever. Still nothing. Then I tapped both the starter and the solenoid and then decompressed and it started. I know this means I need to replace either the solenoid or the starter soon. So where am I going to get a starter for a rebuild universal 11 hp?
