SailNet Community - View Single Post - Standing rigging- Doing it myself
post #15 of Old 05-16-2010
sailor50
As for tools, you'll need a drill (if you are going to upsize with lubricant), spray for stuck pins, wire cutters on deck, tape measure, silicone or 5200, wrenches, pliers. Also if you do this while the mast is up you need a way to hold the tang compression tubes from falling through the mast while you are aloft and a whole lot of stuff. Good luck to you!
sailor50 is offline
